Coolant
Old Mar 18, 2006 | 05:30 PM
6SpdLT1Z's Avatar
Coolant
What's ideal mixture: %coolant to water.
Is 50 the ideal number? What's too much? too little?
The guy at Advance said 70c/30w was fine. He said heck even some people use 100c/0w
Anyways, should I be shooting for 50%? My car uses 14.3L of Coolant and I have 2 Gallons of coolant.
1 Gallon = 3.78L
So I need 1.89 Gallons of Water and 1.89 Gallons of Coolant. Would it be ok to put 2 Gallons of coolant in then fill it up the rest with water?
Old Mar 18, 2006 | 06:12 PM
GreenDemon's Avatar
Re: Coolant
Was this guy trying to sell you a lot of coolant or something?
0/100- best heat transfer- high freeze point, no corrosion protection
50/50- A good compromise, and easy to figure out without measuring cups
70/30- I think it's somewhere around here that you get lowest freeze point/highest boil point. But unless you live in the Barrow, AK, or Death Valley, CA, you probably won't need it.
For the record I've always used 50/50. If you have cooling problems and use this ratio you've probably got something else wrong with your system other than the proper coolant ratio.
And btw yes what you want to do is fine. If I was doing it I'd just put in a gallon of coolant, then a gallon of water, and split the other gallon of coolant between the 2 containers to make 2 gallons of 50/50 mix, and fill till full.
Old Mar 18, 2006 | 08:13 PM
6SpdLT1Z's Avatar
Re: Coolant
Old Mar 19, 2006 | 01:19 AM
LT1 POWR's Avatar
Re: Coolant
Not trying to hyjack your thread here but what type of water should you use. Distilled, filtered or regular tap water.
Old Mar 19, 2006 | 03:42 AM
camaro01ss's Avatar
Re: Coolant
50/50 is the norm. Put the coolant in first.
Old Mar 19, 2006 | 04:37 AM
Bayer-Z28's Avatar
Re: Coolant
I've heard that you're supposed to use distilled water. But I normally use just good 'ole tap water. as long as you don't have a BAD hard water prollem.
I do 50/50. I'll take an empty jug and fill it 1/2 w/ coolant anf fill the rest up w/ water. Are you replacing the DEX w/ green, or vice versa? IF you're switching, make sure you give it a GOOD flush.
Old Mar 19, 2006 | 10:33 AM
GreenDemon's Avatar
Re: Coolant
Use distilled water if you can. A lot of people just use tap water (including me on occasion) but it does have minerals in it that will slowly form deposits in your cooling system.
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
Pwilson59
Sep 3, 2015 08:47 PM
