Conv. top
Old Sep 21, 2005 | 07:22 PM
GreenGobbler's Avatar
Conv. top
My vert. top just stopted going down this weekend at foodlion auto fair I got it back up, is this a hard fix? any help is welcoe thanx.
Old Sep 21, 2005 | 07:45 PM
z28jaz's Avatar
Re: Conv. top
Depends if it's a hydraulic problem or not. My top stopped going down because the contacts in the switch broke. If it's just that not too hard to fix.
Old Sep 21, 2005 | 11:47 PM
gt_biker13's Avatar
Re: Conv. top
Take a look at the pump while someone is pressing the button. One time this happened and it was just a screw loose which caused the motor to turn freely so that it wouldnt move the top up or down.
Old Sep 22, 2005 | 04:17 PM
ishz28's Avatar
Re: Conv. top
My top problem was a bad switch as well. If you can't get it fixed in the near future, you can turn the lever on the hyd. pump to disengage the pump and the top will move much easier.
Old Sep 24, 2005 | 09:53 PM
ZeeVert's Avatar
Re: Conv. top
The manual valve is in the trunk, left side, under a flap in the "carpet".
See this picture:
It doesn't fix your problem, but it will make it easier to maually raise and lower until fixed.
sleeperZ96BT
Sep 9, 2015 08:28 AM
Rittmeister
Aug 7, 2015 01:13 AM
Aug 5, 2015 08:35 AM
Boss002
Jul 24, 2015 10:47 AM
hcarrickz3
Jul 21, 2015 08:46 AM
