college and 2000 to spend
Old 09-07-2011, 02:24 PM
jrz28camaro's Avatar
I found 1 forum on what to get but nothing on their is anything I would even consider doing so I have about $2100 to spend to get things running right. and I am a student right now so the car is pretty much stock except the chokemaster that came with it.
So right now the car has a failing opti has the code for it so obviously that is a must but what about other upgrade what would be the smart path to take right now with it. The car sees 50/50 mix highway and round town driving.
thanks.
jrz28camaro is offline
Old 09-07-2011, 02:30 PM
AdsoYo's Avatar
Re: college and 2000 to spend
Could you post some basic info like year, transmission, anything that could help us out. You can look at my signature or anyone's signature for an idea of useful info.
AdsoYo is offline
Old 09-07-2011, 02:38 PM
6SpdLT1Z's Avatar
Replace the opti and waterpump and save the rest. College is expensive, I just graduated last May.
6SpdLT1Z is offline
Old 09-07-2011, 02:55 PM
I was thinking about doing the coil on plug setup so i never have to wory about the opti again is it worth do that
and a shift kit and 3.73 gears.
its a 95 a4
Old 09-09-2011, 12:18 AM
Mswezey's Avatar
Location: Wichita Falls, Texas - College. DF-Dub, when not in college
i gotta 95 a4 also...and also in college
new opti, plugs, wires
new waterpump ( cheap brand new at autozone)
and i'd start upgrading the suspension..15-16 year old car.. mine is shot
CAI?
Just all depends when your last tune up was, how many miles you got, and how good your car is falling apart on you.
i've had to replace a window motor, need to do drivers side or at least lube it up again.
fuel pump replaced
regulator replaced
opti, plugs, wires
prolly need new 02's
got a new fuel line ($26) from the drivers seat to the fuel rail (kink in mine)
new vacuum hoses (some cracked)
list goes on....
Tunercat!
Mswezey is offline
Z28ELECTRICIAN
10-19-2015 06:36 AM
68camaroboltz
10-05-2015 11:56 PM
pepon214tx
09-20-2015 04:48 PM
scottcba1
09-08-2015 09:52 AM
tomfric
Parts Wanted
07-30-2015 03:01 PM
Quick Reply: college and 2000 to spend
