Cold air...
Old May 29, 2007 | 01:33 AM
Kingjz's Avatar
Cold air...
sup guys i wanted to know whats a good cold air intake to get and whats the average cost ..thanks to all that can help
Old May 29, 2007 | 06:11 AM
transAMdriv3r's Avatar
they are all pretty much the same, just got to find one that you like and can afford. I have a k&n fipk and I bought it new at around 200.
Old May 29, 2007 | 07:09 AM
2000GTP's Avatar
Most of the name brand intakes will run around the same cost. They all accomplish the same thing. Some people have had good things to say about the cheaper Ebay intakes, others have not.
Old May 29, 2007 | 07:22 PM
Kingjz's Avatar
when you order it online does it usually come with everything or do you need more
Old May 29, 2007 | 07:25 PM
oneclean97z's Avatar
online it was 48.99 including shipping. came with everything i needed, works and sounds great. best part is i am 100% positive i can feel a difference. then again this was the most recent mod i have done to my car, still noticed it though. fits a lil tight but hood closes w/o touching it
http://cgi.ebay.com/ebaymotors/ws/eB...B:EOIBSA:MT:11
Old May 29, 2007 | 07:53 PM
2000GTP's Avatar
I didn't even realize in your sig you have an LS1 which uses an airlid system. You can still switch to a cold air intake system, you just have another option to consider though as well.
Old May 30, 2007 | 01:15 PM
goingfasterbmw's Avatar
I had the K&N right around 200. loved that thing!
Old May 30, 2007 | 02:49 PM
Kingjz's Avatar
slither whats up homey....so k&n is a good way to go huh?
Old May 30, 2007 | 02:58 PM
bombebomb's Avatar
They have the k&n filter at summit racing one is $214 and th eother is $175 before shipping make sure if you order from summit, get the $175 its the exact same thing.
Old May 31, 2007 | 08:51 AM
teke184's Avatar
whoa
this is for an LS1 camaro....and people are reccomending the K&N???
if you want the best cai for a air-lid style intake you're gonna want to go with something like the SSRA and any aftermarket lid.
all lids are basically the same when it comes to performance. only difference is look (clear, black, textured, smooth etc), material (plastic or cf) and cost.
and under the lid you can install a small scoop like the FTRA to draw air from under the nose of the car. or you can go one step farther and get a SSRA which has a 2x13" scoop located under the nose of the car and functions as a true ram air at higher speeds.
total will be about $300 depending on where you get it. but it will be the BEST intake for the Z28 style hood...by far!!
Old Jun 4, 2007 | 04:24 PM
Kingjz's Avatar
hey teke where can i find out about the ssra?
Old Jun 4, 2007 | 05:14 PM
Ratlor's Avatar
http://www.speedspecialty.com/store/...p?product=ssra That's the link for the SSRA. Hope it helps you a bit.
Old Jun 5, 2007 | 07:00 AM
teke184's Avatar
typical gains for a reduced temperature intake is 1% power increase for every 10deg of temp drop.
so even if you're only getting a 20-30 deg drop in intake air temps, you're looking at a reasonable amount of gain.
20% x 300hp = 6hp
30% x 300hp = 9hp
and that's assuming a pretty small temp drop, as well as not accounting for any "ram air" affect of the scoop at higher speeds (over 75mph).
PopoFormula
Oct 12, 2015 04:19 PM
WobblySausage
Oct 7, 2015 02:44 PM
football4life
Oct 4, 2015 07:48 AM
greenzee28
Sep 25, 2015 04:29 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
