Coil wire ARCING to water pump
Old Jul 30, 2006 | 08:21 PM
SixSpeedShifter's Avatar
Does anyone have any experience with this? I just replaced the opti spark and the car runs fine - but the coil wire plug is arcing to the water pump housing? What would cause this to happen now as opposed to before the opti swap? Did I not ground something properly? Inuneer? Shoebox? Thanks!
Old Jul 30, 2006 | 08:47 PM
Re: Coil wire ARCING to water pump
Either you don't have it on all the way or you need to replace the coil wire.
Old Jul 30, 2006 | 09:24 PM
95LT1Z28's Avatar
What shoebox said.
Jeff
Old Jul 30, 2006 | 09:25 PM
dannyum89's Avatar
I had the same problem when I changed my opti. My wires were old but did not seem brittle. When I put everything back together and drove for a few hours it started misfireing and backfireing. I checked my wires with an old hairspray trick and saw that many of my wires were arcking. Including my coil wire. Your wires might have been fine until you started moving them. Don't just change your coil wire, you'll be sorry.
Old Jul 30, 2006 | 09:26 PM
dannyum89's Avatar
dannyum89's Avatar
Old Jul 30, 2006 | 09:27 PM
dannyum89's Avatar
Old Jul 30, 2006 | 09:30 PM
dannyum89's Avatar
wow!
Old Jul 30, 2006 | 11:05 PM
Shoebox and all, I thank you for your input. I am replacing the coil wire tomorrow. I will hopefully be able to get away without replacing every spark plug wire as well. It is also worth mentioning that the pigtail connector on the water pump broke - I am 99% sure that I have the polarity correct though. Hopefully that's not a contributing factor in this. Either way, I will be replacing the connector soon.
I'll keep everyone posted.
Old Jul 30, 2006 | 11:35 PM
Originally Posted by dannyum89
wow!
Make use of the delete post option.
Old Aug 1, 2006 | 08:35 AM
In case anyone comes across this problem - the new wire fixed the problem completely. Thanks guys.
Old Aug 1, 2006 | 08:49 AM
Thanks for posting the result. It helps when people make use of the search.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
grgguy
17
Feb 23, 2015 07:57 PM
