codes
Old Sep 24, 2004 | 06:07 PM
cndctrdj's Avatar
codes
111 tcs warnlamp ckt malf
114 tcs enable relay contact ckt open
136 tcs system voltage low
144 left tcs channel will not move
145 rt tcs channel will not move
154 adj. assy. malf
155 ebtcm internal malf
ok so my car had an abs inop light on and i got the codes checked and this is what it came up with
so whats broken on my car
or even better what isn't broken on my car
im guessing i need to fix the tcs system
how expensive is that
Old Sep 25, 2004 | 02:33 PM
cndctrdj's Avatar
Re: codes
anyone know these codes i kinda need your help cause i dont wanna go replacing things thatdont need replacing
Old Sep 25, 2004 | 08:32 PM
HBHRacing's Avatar
Re: codes
it's always hard to get good info on ABS and TC codes, one fault can set a massive amount of codes. I would check your fuses, clear the codes and see whats the first one to come back
Old Sep 26, 2004 | 10:56 AM
cndctrdj's Avatar
Re: codes
i have one fuse that keeps breaking. its the fuse that goes to your interier lights and radio. it keeps blowing but when i replace it for a week its good and all the codes are gone no lights on the dash
i think i need to find out why it keeps blowing and then go from thier
anyone have any idea on how to make it work
Old Sep 26, 2004 | 02:24 PM
HBHRacing's Avatar
Re: codes
tracking down a short is never fun. you can unplug everything that fuse feeds one at a time till it stops blowing. but that is every interior light, the dimmer switch, rear veiw mirror, BCM etc etc etc. have you done anything under the dash like an alarm or radio install? what about had the seats or center consol out? it's not advised but one way to find a short is to take the fuse and replace it with a heavy gauge wire and look for smoke, that will tell you where the short is. but like I said, it's not advised
Old Sep 26, 2004 | 11:55 PM
cndctrdj's Avatar
Re: codes
ya i took the console out why is that a problem?
Old Sep 27, 2004 | 09:59 AM
HBHRacing's Avatar
Re: codes
follow the orange wires. I am willing to bet that one is grounding somewhere from being pinched.
Old Sep 28, 2004 | 01:03 AM
cndctrdj's Avatar
Re: codes
i know i have an exposed orange wire somewhere
i am gonna get on that in the mourning
thanks
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
