code 22
Old Nov 19, 2014 | 10:53 AM
  #61
Black93lt1's Avatar
Re: code 22
Ha nope its like 42° here
Old Nov 19, 2014 | 10:54 AM
  #62
GaryDoug's Avatar
Prominent Member
Re: code 22
The ones at Harbor freight are cheap (~$6) and fairly good except for the test leads. If you buy one, use your old leads instead. if that is the case.
  #63
Black93lt1's Avatar
Re: code 22
And the block hasn't been warm since Saturday
Old Nov 19, 2014 | 10:55 AM
  #64
Black93lt1's Avatar
Re: code 22
Should I have been on 20k measure or the 2000 measure when I did the test
Old Nov 19, 2014 | 10:59 AM
  #65
GaryDoug's Avatar
Prominent Member
Re: code 22
It shouldn't matter, but to get a real reading put it on the 200k range.
Old Nov 19, 2014 | 11:38 AM
  #66
Black93lt1's Avatar
Re: code 22
Went to test with the 200k measure and the battery died replaced the battery measured a 04.4ohms then went to the 2000 measure that showed a 1880 before now shows a 1210ohms
Old Nov 19, 2014 | 11:39 AM
  #67
Black93lt1's Avatar
Re: code 22
Battery use to show a 15.1v and now shows 11.9v
Old Nov 19, 2014 | 11:58 AM
  #68
GaryDoug's Avatar
Prominent Member
Re: code 22
The voltage measurement looks better with the new battery, but I still don't trust the ohms readings. The coolant temp sensor should read about 7000 ohms (or 7 kohms): 4th Gen LT1 F-body Tech Articles
Was the 4.4 ohms reading possibly a 4.4 kohms reading of the tps?
It's possible the meter may have damage that affects the ohmmeter reading circuit.
Old Nov 19, 2014 | 12:03 PM
  #69
Black93lt1's Avatar
Re: code 22
Nope both of those were for the ect...the tps still has no change
Old Nov 19, 2014 | 12:16 PM
  #70
GaryDoug's Avatar
Prominent Member
Re: code 22
Looks like the meter is bad when measuring resistance.
Honestly, I would order the cheapest TPS I could fine just to try it out. I know the good Delco ones cost about $50 but you can get Chinese-made ones for about $10. If it works, then you could opt for the better one.
Old Nov 19, 2014 | 12:20 PM
  #71
Black93lt1's Avatar
Re: code 22
Ok I'll have to look around to see if I can find one
Old Nov 19, 2014 | 12:53 PM
  #72
GaryDoug's Avatar
Prominent Member
Re: code 22
for reference:
Throttle Position Sensor TH47 Chevrolet Cadillac Buick GMC Pontiac Oldsmobile | eBay
also Rockauto has all prices from cheap to expensive
Old Nov 19, 2014 | 03:54 PM
  #73
Black93lt1's Avatar
Re: code 22
Ok so I ordered that tps and should be in between the 22 and 28
Old Nov 26, 2014 | 03:37 PM
  #74
GaryDoug's Avatar
Prominent Member
Re: code 22
Are you saying now that the starter doesn't work? Check all the fuses; you may have blown one changing the tps.
Let's keep the conversation going in here because we lose continuity via email. Just give me an email to let me know you made a new post here.
Old Nov 26, 2014 | 03:44 PM
  #75
Black93lt1's Avatar
Re: code 22
Ok...and idk if the starter is out I did notice that my radio is not on either so I have checked all the fuses under the hood an now moving to the one next to the door....
