... Clutch safety switch
Old Sep 14, 2006 | 03:44 PM
stans82z's Avatar
... I'm looking for a clutch safety switch for my 82 Z28. Neither Classic Industries nor Year One have them and they're no longer available at the dealer. I may be able to find it online if I had the GM part number, but I don't have it. Does anyone have any ideas? Thank you in advance.
Old Sep 14, 2006 | 07:02 PM
95LT1conv's Avatar
Re: ... Clutch safety switch
if your talking about the switchthat prevents the car from starting unless the clutch is pushed in, advance auto has 3 different ones starting at $15
Old Sep 14, 2006 | 07:41 PM
stans82z's Avatar
... Thanks much, I'll check Advanced Auto out.
Old Sep 14, 2006 | 08:53 PM
Onebad97Z28's Avatar
I have a 97 camaro w/ a M6 and most of the time i dont have to push my clutch in, but once in a great while i do? does that mean that my clutch safety switch is bad? i actually dont mind not having to push the clutch in cause i never leave it in gear, i use the E-Brake. Plus, im thinking about putting a remote start kit on it, so would i be able to just unhook the safety switch in able to let the kit work?
Old Sep 14, 2006 | 09:13 PM
95LT1conv's Avatar
yea its probably sticking
Old Sep 14, 2006 | 09:18 PM
stans82z's Avatar
... I'm not so sure about your situation, Onebad. I don't know of anyone that has hooked up a remote starter in a car with a manual trans. It seems as though there'd be a way. On my '82, without the clutch safety switch, if the car is in gear you or someone could turn the key and it will lurch forward , or backward if it's in reverse. With the switch on it the clutch has to be fully depressed to start the car. I went through some very deep water and the switch was ripped right off. At least I think that's why it came off! I did see the ones mentioned at Advanced Auto and will stop in tomorrow. Thanks for the help!
.... Stan
Old Sep 14, 2006 | 09:23 PM
with mine, when i turn the key, without depressing the clutch, it starts just like an automatic. no lurching. and i never leave it in gear when parked anyhow, so i wouldnt have any accidental lurchs.
Old Sep 14, 2006 | 09:31 PM
stans82z's Avatar
... Yeah, I'm sure you shouldn't be able to do that. I agree with 95LT1conv, your clutch safety or starter switch is sticking.
Old Sep 14, 2006 | 09:46 PM
so, is there a way to disable the safety switch so that i caould install a remote start kit? i dont see a need for the safety switch as long as i own the car. and its been starting with out pressing the clutch for over 2 yrs now.
Old Sep 14, 2006 | 10:00 PM
stans82z's Avatar
... I'm sure it can be disconnected. It sounds like yours is already disabled, Onebad. On the newer cars I'm not so sure what would happen if you opened up that loop, all you can do is try.
Old Sep 14, 2006 | 10:16 PM
You unplug the switch and connect the harness leads together to disable it.
HectorM52
Jan 30, 2015 11:08 PM
Redbird
Sep 14, 2002 09:18 AM
kandied91z
Aug 4, 2002 02:53 AM
Redbird
Aug 2, 2002 06:50 PM
Redbird
Jul 20, 2002 06:08 AM
