Changing fog lights or fog light bulbs
Old Dec 20, 2005 | 07:50 PM
ddj19852003's Avatar
I recently bought replacement bulbs for my fogs light because that what auto zone told me i needed. Is this right or does the whole light get replaced like head light and if the bulbs are the right replacement how do i replace them i look at it breifly and was stumped.
Old Dec 21, 2005 | 06:49 AM
94_Z28_guy's Avatar
Re: Changing fog lights or fog light bulbs
You only need to replace the bulbs.
There are two plastic pins that hold the light assembly into the bracket. A long small flat head screw driver can get under the pin head to pull them out. The problem is getting them back in.
Old Dec 21, 2005 | 07:03 AM
Amped96's Avatar
I guess you are talking about a 93-97 camaro??
94_z28_guy is pretty much right...undo the torx adjustment screw and the two plastic push pins that hold them in...
I removed my windsheild washer fluid resivior last summer...MAN, they are REALLY easy to change now. Don't have to remove the light at all
Old Jan 2, 2006 | 02:34 PM
dz's Avatar
dz
Goddamn, I hate to rehash an old thread but I'm in the middle of changing my bulb and just did a search on it because it was killing me. I removed the bottom air damn piece, the whole right plastic piece and I'm trying to take the rivets out. This is killing me!
I'm going to go try those two push pins now. I wish I would've searched first
Old Jan 2, 2006 | 08:41 PM
yeah make sure you have the needle nose pliers they were the KEY
Old Jan 3, 2006 | 11:41 AM
Chevamaro's Avatar
How easy is it to remove the reservoir? My car's previous owner hit a deer, and while the body/paint work was done right, the driver's side fog light was left pushed up tight by the center plastic (so I don't think it's possible to pull the pin on one side... and, of course, that's the bulb that's not working).
Old Jan 3, 2006 | 11:49 AM
94Z28/SSw's Avatar
The easier way would have been pulling the three push pins underneather the front clip, pull that down and reach up in there and pull the bulbs, take 5 to 10 min, alot easier than screwing with the removal of the actual lamp
Old Jan 3, 2006 | 06:30 PM
mook99TA's Avatar
Does this go for TA foglights too?
Old Jan 4, 2006 | 10:41 AM
94Z28/SSw's Avatar
I would think so, they are in the same area as the 93-97 camaro fog lamps
Old Jan 20, 2006 | 12:10 PM
jhthornley's Avatar
This site ROCKS..
I just replaced my driver side fog bulb..
When I first looked at it I just sat and stared... "how they H*!! do you get this thing out?"..
When I read this thread and realized that the side screws were just plastic pins... ah ha..
John T
Old Jan 20, 2006 | 01:40 PM
94BlackBowtie's Avatar
Don't know if everyone is finished yet or not, but next time...
http://www.bfranker.badz28.com/fbody/fogs.htm
That is quite helpful.
silvermansteve
Mar 4, 2015 05:02 PM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
siguy
Nov 27, 2014 10:07 AM
30thZ286speed
Aug 3, 2002 04:54 AM
