car wont start some times
Old Jun 13, 2008 | 06:35 PM
95firebird3.4's Avatar
ok well sometimes if i got to start my car it wont start. i dont get a click or anything. now if i let out the clutch and and push it back in most of the time it will start but today i had to do it 2 or 3 times. and it doesnt do it all the time. i changed the starter and battery with no luck.
Old Jun 13, 2008 | 07:14 PM
Oxygen454's Avatar
Ya I wouldent say it was a batter if it does start. Check you battery connections, if they are even a bit loose this will happen. Also, I dont have a standard but I am pretty sure there is a safety switch that tells the car when the clutch is in or out. Check up on that.
Old Jun 13, 2008 | 07:16 PM
Oxygen454's Avatar
Another question, when your camaro doesn't start, is there any lights on in the interior? Are you still getting power to everything else?
Old Jun 13, 2008 | 10:25 PM
yah i have full power. and no lose connections
Old Jun 16, 2008 | 11:44 AM
MislMan's Avatar
Sounds like there is a microswitch connected to the clutch linkage (behind the pedal) that is acting up. I believe there is a switch that activates when you press in the clutch that acts like a safety switch so someone doesn't try to start the car without pressing in the clutch. The switch interrupts sending power to the starter until the PCM confirms the clutch is pressed in.
I don't have a 6-speed manual so I do not know this for certain.
Later ... Larry S.
Noenav
Mar 1, 2019 07:38 AM
Queens94z28
Dec 20, 2014 09:11 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
