cannot program new keyless remotes
Old Apr 14, 2005 | 02:11 PM
gsewell_uk's Avatar
Hi,
I have bought two new keyless remotes for my 1996 Camaro Z28. THe numbers on the back match my existing remote:
GM 16245100-29
FCC ID AB01502T
My method was:
turn ign on/off
remove radio fuse
turn ignition on/off three times - doors lock/unlock themselves
hold lock and unlock buttons on my existing remote - again door lock/unlock themselves
hold lock and unlock buttons on my new remotes - nothing happens
remove key
replace fuse
What am I doing wrong - or have I somehow got two new remotes that both do not work?
Old Apr 14, 2005 | 02:16 PM
nathan96's Avatar
Re: cannot program new keyless remotes
I ran into the exact problem that you had, I too would like to know, since I returned the one I got from the dealer, but still have the one I got on ebay. I never was able to get either one to work. I tried replacing batteries etc. and nothing ever seemed to work
Old Apr 14, 2005 | 02:53 PM
hatredizm's Avatar
If you look inside them, they usually say something like " to reset press unlock and lock for 7 seconds near car ". Mine says that in the original one also.
Old Apr 14, 2005 | 03:07 PM
Not sure why you are first going through the programming sequence for your fobs that already work. Try eliminating that step. Also, if no lock-unlock is happening with the new remotes, they may need batteries.
Old Apr 14, 2005 | 03:20 PM
nathan96's Avatar
It been a while since I gave up trying, but as I recall you have to use one of the fobs that is programmed correctly first then add the new ones, at least that is what I recall from the owners manual. I tried any number of things, including not using the one that worked in the sequence, the battery out of the one that I knew worked, basically everything I could think of. It is just easier to unlock with a key. LOL
Old Apr 14, 2005 | 03:51 PM
moparman's Avatar
How do you tell if the fob or the module in the car is the problem?
Old Apr 14, 2005 | 03:54 PM
gsewell_uk's Avatar
According to the owner's manual, you need to reprogram all remotes at the same time. The fact that I can reprogram the original means that the procedure is almost correct. I have tried changing batteries - and again only the original fob works.
Old Apr 14, 2005 | 06:47 PM
The programming procedure on my Tech Page doesn't say anything about doing anything with the original fob. You do have to program all new fobs. I would say your new fob is no good.
Old Apr 15, 2005 | 02:36 AM
gsewell_uk's Avatar
Shoebox,
Now I am getting confused as your web site says:
NOTE: Always program both transmitters when replacing a lost or damaged transmitter. The first transmitter code programmed will always be in both memories until a second transmitter is programmed within the same sequence.
So I understand that to mean that if I programmed up the new fob and did not register the original fob at the same time that only the new fob would be recognised.
Old Apr 15, 2005 | 07:35 AM
Re-reading that, I think the purpose is meant to purge the memory of a transmitter lost or stolen. It may be that you need to do both, so carry on.
I don't think this has anything to do with your problem, though. If the programming procedure works with your existing fob and not with the new one, I would say it is the new fob that has a problem.
Aaront810
Aug 29, 2020 09:34 PM
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
