Can i take off my ecu on 92?
Old Feb 19, 2008 | 08:34 PM
92slo-maro's Avatar
I have a 92 rs v6 im putting a stroker motor in with a th350 tranny. Can i take the computer off? Do i cut the unused wires from under the hood? what is the best way?
Old Feb 19, 2008 | 10:00 PM
Is the stroker engine carbed or fuel injection?
Someone told me to hook up the ones i need and cut the rest.
Hook up the ones of what? Some of the ECU circuits?????
Old Feb 19, 2008 | 11:08 PM
92slo-maro's Avatar
92 ecu
cut the unused wires from under the hood. It has carb.
Old Feb 20, 2008 | 02:22 AM
Zepher's Avatar
You will probably want to put in an aftermarket speedo.
Here is a setup in my friends 82 T/A, yours can use the same gauges, just laid out in your camaro cluster.
Old Feb 21, 2008 | 11:56 AM
white97T/A's Avatar
That looks good, I wish it was as easy to do something like that in a 4th gen.
Old Feb 21, 2008 | 04:19 PM
92slo-maro's Avatar
Are the gauges the only thing that the computer still controls? So if i remove the computer i will have to install all new gauges? Id rather not!
Old Feb 21, 2008 | 04:32 PM
Zepher's Avatar
The Speedo on your car requires the computer since the VSS Buffer is built into it.
to run the speedo without the computer, you will need an external VSS Buffer from an 86-89 Firebird (camaro's had mech speedos until 89).
Or you could just get a gauge cluster from a 89 and older Camaro and just hook up a mech speedo cable.
RUENUF
Mar 13, 2016 03:37 PM
SEOJustin
Sep 24, 2015 04:39 PM
Aug 7, 2015 08:52 AM
Jonnybegood
Parts Wanted
Feb 10, 2015 07:50 AM
