can a door lock switch cause door locks both to not work?
Old Nov 9, 2004 | 06:54 PM
PredatorZ28's Avatar
my door locks do not work , i figured it was my alarm but i took it to the alarm place and they took the alarm out of the system and yet they still do not work they saided it probably either the body control module or the switch but i unpluged the passagers side switch and the drives still does not work.. the driver side it new . the passagers side will unlock if u push it a couple of times but thats all and the driverside does nothing. this all happend when i blew the acc fuse non related
Old Nov 9, 2004 | 06:57 PM
Red_94Formula's Avatar
Re: can a door lock switch cause door locks both to not work?
The passengers side will not work when the drivers side is broken. Sounds like that is your case.
Old Nov 9, 2004 | 07:54 PM
Either switch can cause either lock not to work. Also, a 1995 does not have a BCM.
Old Nov 10, 2004 | 01:07 PM
ishz28's Avatar
In my 94Z, the ground wire for the lock switch (pass. side) broke at the connector causing both locks not to work. Check the wires at both connectors.
Old Nov 10, 2004 | 09:02 PM
XxXTransAmXxX's Avatar
I know when wiring alarms on Fbody's or any car that has a 5-wire swtich the PASSENGER SIDE is the Master Switch for some odd reason....
Old Nov 11, 2004 | 09:42 AM
mhhodges76's Avatar
My locks do not work either. They have not worked since I have had the car (6 months). I have an aftermarket alarm on the car with keyless entry, remote start and car alarm. I just assumed the alarm was not hooked up correctly. I will check my passenger side lock wires today. It sucks having to manually unlock the passengers side. How stupid it would look if I used my remote start to start the car but had unlock my doors manually with the key.
Old Nov 11, 2004 | 06:34 PM
just my point i have a remote start lol... there is a box on the pass. side kick panel where the alarm was hooked up what is that called?
Rod Bender
Jan 3, 2015 03:15 PM
Jeff1904
Jan 3, 2015 12:00 AM
ro2207
Dec 4, 2014 06:18 PM
Roshambo
Sep 4, 2002 11:25 AM
