camaro fans question 95 z28
Old Oct 28, 2013 | 10:32 PM
Jake Guzman's Avatar
I have a 95 z28 I've sorted out all my transmission issues ii just have a question. My cooling fans won't work because I don't have freon in the system and Im aware of that. They work when there's freon in there but it all leaked out. If I buy a SLP fan switch will I need freon in the car or Will it work on its own.
Old Oct 29, 2013 | 08:30 AM
bobdec's Avatar
Re: camaro fans question 95 z28
Lack of refrigerant will NOT prevent fan from normal operation. AC pressure will run the fans, but only when pressure is there. Here is a test .. with key on engine OFF short pins 5 and 6 together in the ALDL connector. Here is a PIC http://shbox.com/1/DLC_wiring.jpg make sure you use the 1995 diagram. That will light the SES indicator, run the fans. (Also picks AC clutch, EVAP solenoid, EGR solenoid, and air pump relay). If the fans do not run then check the fan fuse, if OK then swap the three fan relays with the air pump, fog light and ac relays. If still no fans swap everything back and let us know. Good luck
Old Oct 29, 2013 | 09:55 AM
Whenever I put refrigerant in the fans could come on when they were supposed to. The relays and everything are good I've been through all the. Trouble shooting just replaced temp sensor relays and fans. I just want to know if I get a fan switch will I need air pressure in the system
Old Oct 29, 2013 | 11:27 AM
The fans come on for three specific reasons:
1 - The A/C or defroster (which uses the A/C) is running - fans come on at low speeds
2 - The A/C or defrost is not on, but the coolant temp has reached 226*F (low speed), and they will switch to high speed if the coolant temp reaches 235*F. Are you saying that the coolant temp is higher than these temps, and the fans do not come on?
3 - Certain daignostic trouble codes cause the fans to come on, but that is obvioulsy not relavent to your issue.
The key question is.... how hot is the coolant getting?
Old Oct 29, 2013 | 03:10 PM
Originally Posted by Jake Guzman
... I just want to know if I get a fan switch will I need air pressure in the system
No a/c pressure needed for fan operation via temp control or external switch. The reason the fans come on with the a/c is to make the a/c perform better.
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
ChrisFrez
Dec 7, 2014 06:01 PM
ChrisFrez
Nov 30, 2014 08:41 AM
Jul 4, 2005 05:00 PM
