Calling.... electrical gurus!
Old Mar 2, 2009 | 10:54 PM
porksoda's Avatar
I have a 1994 trans am and my taillights are acting up ridiculously! I've replaced bulbs and didn't fix the problem so now I want to replace the sockets. What I need is the part numbers for the sockets in the taillights. Also can I buy these at like Autozone or is it dealer specific part?
Old Mar 3, 2009 | 12:59 AM
MikeGyver's Avatar
What do you mean they're acting up? are they LED's, or normal bulbs?
Old Mar 3, 2009 | 05:30 PM
n2ceptor's Avatar
I just went to my local dealership and they had the sockets in stock.. Just told them what vehicle, 93Z... Cost around 12 dollars... But you will need the die-electric grease... It didnt come with the socket assembly...
Old Mar 4, 2009 | 08:43 PM
crazyswede1027's Avatar
I would test some wires before you going replacing parts. Socket is likely cause of problem but a faulty ground could also be an issue. Check the brake switch to make sure that is good. I would also meter the + wire to see what you get. What exactly is it doing, that may help to get a better answer.
Old Mar 5, 2009 | 12:47 PM
porksoda's Avatar
It's kinda hard to describe what it's doing. I have a video somewhere but I have to find it.
Old Mar 9, 2009 | 06:03 PM
Granite00's Avatar
I'm just going to throw this one out there. When you say they act up, does that mean the lights that are supposed to light up get dim and other lights get brighter? If so, I would agree that you need to look for an fix a bad ground. If not, we need a way better description of what the lights are doing.
Old Mar 11, 2009 | 04:25 PM
porksoda's Avatar
Here is a vid of what the car is doing. Ignore the part about the gauges not working.
Old Mar 12, 2009 | 04:44 PM
Kevin Blown 95 TA's Avatar
Agree - check the ground and run a separate one all the way back if you want. If you are getting weird voltages back there, I'd bet it's a bad ground.
Old Mar 15, 2009 | 04:43 PM
Granite00's Avatar
Just looking at what the brake light do, you are loosing the right side completely and they are slow to light back up. It seems like there's a bad ground on that side that can't even run the brake lights when you put them on. Try running another wire to one of the sockets ground wire and screw it into the sheet metal of the car in the back where the lights are. If that's it, your lights should get brighter and light up quickly again.
The left side turn signal could be a bad bulb, but you said you have already replaced them. Just for grins, swap the bulb in the right socket that works for the one in the left. If it's not that simple, you'll need to do some testing with a test light to confirm a wiring or socket problem.
football4life
Oct 4, 2015 07:48 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
Daluchman1974
Sep 11, 2015 06:12 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
tdigger9899
Sep 7, 2015 10:56 AM
