Calling all Know-it-alls
Old Mar 8, 2006 | 07:55 AM
  #16
97FormulaWS-6's Avatar
Re: Calling all Know-it-alls
I've snapped more normal sockets doing stuff like this than I have fingers; thus the reason for the Impact comment.
Old Mar 8, 2006 | 09:31 AM
  #17
SS RRR's Avatar
Just stating it's not necessary to use an impact socket.
Old Mar 9, 2006 | 05:03 PM
  #18
94arcticwhiteM6's Avatar
Originally Posted by RE AND CHERYL
Before you go through all this trouble. Those look like factory locks. Last I checked, GM only osed like 12-15 different locks. You dealer should sell replacement keys and have them in stock. Just tell them you need to try them all to find the right one.
most dealers dont stock them and generally wont help you. when a customer tells me they lost the key i point them to the serivce department to have them hammered off. if you want to attempt to replace them, take the picture of the nut to a chevy dealer and they can order a replacement from mcgard and it takes about 2 weeks.
Old Mar 9, 2006 | 05:10 PM
  #19
CamaroSS30thAnn's Avatar
hahah mcgard , i used to work there
Old Mar 9, 2006 | 10:06 PM
  #20
sleeprsteve's Avatar
I have seen them removed by heating the nut with oxy acetylene and using vice grips. heating the nut also heats the wheel stud and it will expand (lengthening) releasing the tension on the nut. heat the nut quickly as the trick is keep the wheel cool. Good luck!
Old Mar 10, 2006 | 03:08 PM
  #21
user1930's Avatar
Weld a 3/4" heavy hex nut onto the end of the wheel lock and you're done. The lock is junk anyway without a key. Simple and easy.
Old Mar 10, 2006 | 05:44 PM
  #22
1 Nasty Bird's Avatar
Just did this 2 days ago on my buddies t/a. Go to sears and get a craftsman bolt out set. We ended up using a 3/4" size with an impact gun. Put the socket over the lock, couple taps with a hammer to make sure its seated descently, air gun and voila, pretty much as easy as having a key honestly.
Jeff1904
Jun 5, 2016 05:00 PM
LT14LIFE
Nov 15, 2015 06:22 PM
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
drt
Sep 27, 2015 04:39 PM
