a/c problem
Old Sep 19, 2005 | 10:20 PM
will69camaro's Avatar
a/c problem
Not sure where this belongs so i'll post it here. Anyone know what my problem might be with my a/c? It worked fine and had been working fine since i bought it (little over a month now) and after being parked for a week i hop in and the a/c doesn't work! I checked the belts, fine. I checked the fuses, fine. It doesn't blow even the least bit chilly! It was working fine before being parked for a week. No unusual sounds like the compressor is dying etc...Do you think it just has a leak and finally leaked all the way out?
Thanks,
William
Old Sep 20, 2005 | 05:59 AM
Kataklysm's Avatar
Re: a/c problem
If its blowing air then yes you most likely leaked all the R134a out of it. You need to add dye to the system and then use a blacklight to check for leaks.
HectorM52
Jun 23, 2016 08:42 PM
HarleyZ28
Oct 5, 2015 06:23 AM
alphaauto
Feb 5, 2015 05:25 PM
Duke
Sep 3, 2002 02:48 PM
IROC5.7TPI
Aug 13, 2002 01:29 PM
