A/C compressor... clutch or no clutch?
Going to buy a re-manufactured A/C compressor and according to www.partsamerica.com there is an option to buy one w/ or w/out a clutch?
Am I wrong to think the 4th gen f-body compressors have a clutch?
just about every compressor has a clutch, otherwise they would be pumping any time the engine is running. Technically you can swap the clutch over from your existing unit if it's still good, but you need a special puller to get it off and being a wear item you might as well replace the whole thing while you're there.
