A/C blows to floorboards... but has vacuum?
Hey guys. Just got my compressor and most of the rest of the A/C system replaced. Fired it up and wouldn't you know it now it only blows to the floorboards. I saw Shoebox's site for checking the vacuum lines. I pulled the vacuum line from the check valve to the inside of the cab and got good suction there. I can't see any visible problem with that line but the switch doesn't appear to be doing anything. If I unplug the multi colored line plug I don't get suction from the black line... leading me to believe it's either pinched or broken somewhere in between but I can't see much of it... Anyone had this particular problem, or have any suggestions?
Jonota
Jonota
Re: A/C blows to floorboards... but has vacuum?
Check the vacuum line that goes from the check valve to the vacuum tank that is under the battery/radiator overflow tank.Mine was broken about 12 inches forward of the check valve.those plastic lines get brittle with age,heat etc.
