A/C blows to floorboards... but has vacuum?
Old Aug 3, 2006 | 11:31 PM
jonota's Avatar
Hey guys. Just got my compressor and most of the rest of the A/C system replaced. Fired it up and wouldn't you know it now it only blows to the floorboards. I saw Shoebox's site for checking the vacuum lines. I pulled the vacuum line from the check valve to the inside of the cab and got good suction there. I can't see any visible problem with that line but the switch doesn't appear to be doing anything. If I unplug the multi colored line plug I don't get suction from the black line... leading me to believe it's either pinched or broken somewhere in between but I can't see much of it... Anyone had this particular problem, or have any suggestions?
Jonota
Old Aug 4, 2006 | 12:29 AM
JB94's Avatar
Re: A/C blows to floorboards... but has vacuum?
Check the vacuum line that goes from the check valve to the vacuum tank that is under the battery/radiator overflow tank.Mine was broken about 12 inches forward of the check valve.those plastic lines get brittle with age,heat etc.
Old Aug 4, 2006 | 12:40 AM
jonota's Avatar
Found the problem, the line to the selector switch was pinched by the heater core cover. All fixed now!
magman
Apr 15, 2016 03:08 AM
drt
Sep 27, 2015 04:39 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
