A/C Blower Motor... Need help quick.
Old Jan 28, 2006 | 12:37 PM
12sec97Z28's Avatar
Couple of quick questions. 97 Z28. My A/C is leaking from near the firewall and the blower motor is making a loud buzzing noise that starts getting really loud on the highest two levels. Oh, and A/C doesn't blow as hard as it used to on high.
1. What should I check
2. How do I check to see if there is debris in the blower motor box?
3. I found the blower motor under the passenger side dash, but how do I check it to see if it is bad?
Thanks alot for your help.
Old Jan 28, 2006 | 01:41 PM
2001NBMZ28's Avatar
Re: A/C Blower Motor... Need help quick.
Don't know what's going on with the AC leaking, but had leaves in my blower motor box making noise before. I unplugged the connector to the motor, removed the three screws and it pulled right out. LS1's might be a little different...hope this helps.
Old Jan 28, 2006 | 03:18 PM
12sec97Z28's Avatar
Thanks. I just got back in from getting rained on halfway through working on it. So much for "covered" parking! Did have leaves in the blower box. Also had a piece of foam looking insulation. Should I be worried about that?
I also confirmed that the leak is coming from the firewall, but i can't see a hose or anything leaking in the engine compartment. Any suggestions?
Old Jan 28, 2006 | 04:39 PM
2001NBMZ28's Avatar
I wouldn't worry about the foam insulation - too hard to try and figure out where it came from. The AC is supposed to "leak" condensate water to the outside (does it through a small hose on the firewall on mine) hard to see unless you get under the car. Must be nice weather in Houston, haven't had my AC on in a while.
Old Jan 28, 2006 | 04:49 PM
12sec97Z28's Avatar
If you call showers all day nice weather. But yeah, it's still around the 70s as a high, and not having my ac can get annoying sometimes. I think I'm just going to let it ride for a while and see if the A/C loses charge again. Thanks for the help.
AviatorDave
Dec 19, 2016 06:35 PM
magman
Apr 15, 2016 03:08 AM
RUENUF
Mar 13, 2016 03:37 PM
bunker
Jan 30, 2016 08:09 PM
WPHIG2
Aug 27, 2015 06:37 AM
