Bung for trans temp sensor
Old Jul 7, 2011 | 06:37 PM
19z28camaro02's Avatar
So I need to weld a bung on to my transmission pan for my temp sensor. The pan is a Derale, zinc coated steel. I know very little about welding, what can I use for a bung? Or can I just weld a nut onto the pan?
Old Jul 7, 2011 | 07:29 PM
rv93's Avatar
Re: Bung for trans temp sensor
if its only zinc coated, you should be able to grind off the zinc in a spot, then weld the nut there. just make sure you protect it from rust afterward
Old Jul 7, 2011 | 08:07 PM
Just had a thought. The sensor and the fittings that I have that cam with it are all pipe thread. Whats Gunna be the easiest way to do this.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
