brake lights
Old Nov 15, 2012 | 05:51 PM
chevys89's Avatar
brake lights
my brake lights are bright when my headlights are on like if you was pushing on the pedal but the third brake light don't come on i need help tryed everything new brake switch, fuse is good and all bulbs are good
Old Nov 19, 2012 | 03:03 PM
93Z28rare's Avatar
Re: brake lights
You may have the bulbs placed incorrectly in the socket. When that occurs, the wrong filament lights up (in this case the brighter one), and it may appear as if the brake lights are on. Make sure you match the pattern on the inside of the socket with that of the bulbs. The bulbs have these small notches, and one is higher than the other.
Hope this helps.
Old Nov 23, 2012 | 12:34 PM
chevys89's Avatar
Re: brake lights
thanks but i didn't touch any bulbs it just happen one day I was driving and I backed up into the drive way and my mom said your brake lights are still bright with I got out.
Old Dec 12, 2012 | 11:21 AM
93Z28rare's Avatar
Re: brake lights
So the car was off, and the lights were still on? Did you properly adjust the brake light switch? Thread in the switch too much and the lights won't come on. Thread in too little and the lights stay on. It might be the latter if the switch is not adjusted correctly. This would also cause the brake lights to stay on even with the car off and the brake pedal not pressed. Hope this helps.
Old Dec 12, 2012 | 09:45 PM
GaryDoug's Avatar
Prominent Member
Re: brake lights
If when this happens, the third brake lamps do not light up, but in normal braking operation they do light up, the problem may be in the hazard/turn switch circuit. When this happens, do the front ones light brighter also?
Old Dec 17, 2012 | 08:12 PM
chevys89's Avatar
Re: brake lights
no they dont get brighter but is a new column. but it was doing when i had to old column in.
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
