brake lights
Old Jul 15, 2008 | 02:33 PM
pologreenZ's Avatar
Angry brake lights
1997 z28 30th
when night time running lights come on my brake light on drivers side will not work told it was a bad relay but cant find it, Also my radio will go out if i hit a pot hole or a bump somtimes when it goes out windows wont work whats up with that
1997 30th anv polo green 18'' crome junk granitelli maf, trickflow intake tube, hypertech programer
Old Jul 15, 2008 | 04:46 PM
BUBBA's Avatar
Check you manual, or perhaps, Shoe's site to see which accessories have which fuses and check those fuses. For a start. Also, if a light doesn't come on at all, probably burned out. JMHO
Old Jul 15, 2008 | 05:24 PM
The radio and the power windows are fed off the "retained accessory power" (RAP - the circuit that keeps the radio and window powered for 10 minutes after you turn the key off) circuit of the body control module (BCM). Could be a problem with the BCM or the connectors. Not an unusual problem.
Shoebox's website, with wiring diagrams:
http://shbox.com/1/4th_gen_tech1.html
Old Jul 17, 2008 | 09:43 AM
pologreenZ's Avatar
Lightbulb brake light prob
thanx guys the bulb is new as far as the other replies ill check in to that
thank you again
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
