brake light issues-ideas? and others
Old Jul 25, 2007 | 03:25 PM
1QUIKTA's Avatar
I have a 1997 Trans Am and the brake lights are not working, except for the high mount light. I installed a new switch at the brake pedal as well. Any ideas? I did a search and could not find anything that worked.
Also, the headlights come up with the parking lights. Is that normal? I don't remember my 94 doing that. Only 1 (drivers side) daytime light comes on and all bulbs have been replaced and fuses checked.
Any help would be appreciated,
Chris
BTW: We just reinstalled the engine. Would there be a connection somewhere that may have caused this?
Old Jul 26, 2007 | 04:02 PM
1QUIKTA's Avatar
Looks like a broken wire in the steering column is to blame. If you move the tilt up and down you will get some brake lights. I will have to check the others later.
Old Jul 26, 2007 | 06:20 PM
1QUIKTA's Avatar
OK, question. I have the assembly from a 95 Formula that we parted some time ago. Will this lever and wiring fit my 97? And what is the best way to replace this? Is there a simple way of just replacing one wire?
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
