brake light on....
Re: brake light on....
On the brake control valve where you see the brake lines coming out of is the brake control valve. On the top is a 2 pin connector with a tan/white wire and a black/white wire. Disconnect it and see if the light goes out. If you don't want to pull that connector or can't find it. On the passenger fender near the positive cluster is 5 ground wires bolted down for a ground. Take them off the bolt so they are not touching ground and see if the light goes out.
Also when you get back to us on that, let us know if you have DRL's.
did the light just come on by it self or were you messing with the brake system? I believe what you just unplugged is there is a sensor in the proportioning valve that senses pressure, if one side has less pressure than the other then the light will come on. Its a sign that you have air in the system or a leak of some kind.
Originally Posted by PredatorZ28
Ttt
quick fix? leave unplugged ?
Leaving the light unplugged is not a "quick fix". You may have a leak in one of the braking circuits or you may have air. Or the switch might be faulty. Or the master cylinder could be leaking or worn out. You need to inspect the braking system for leaks. You may need to bleed the system. It might be a good idea to have it looked at by a qualified mechanic.
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
