bolt ons
Old Nov 3, 2014 | 10:54 PM
cristian1311's Avatar
bolt ons
I just got my camaro and I already put a cold air intake, but what other bolt ons can I put on while still being able to pass smog? I have no budget.
Old Nov 4, 2014 | 08:35 AM
Re: bolt ons
Need year of car, model, engine and trans info before we can help.
Would also be helpful to know where you live, and what emissions you need to pass (CA for example, is way more demanding than FL).
You need a "Signature".
https://www.camaroz28.com/forums/lt1...nature-879835/
Old Nov 5, 2014 | 11:09 PM
Re: bolt ons
It's a 93 z28 383 stroker. And I live in California. Thank you
Old Nov 6, 2014 | 06:39 AM
Re: bolt ons
I would suspect that a 383ci stroker would already have significant modifications - e.g. larger throttle body, larger injectors, more aggressive cam, ported heads, headers, improved catback, PCM tune, etc.. The more detail you can provide regarding the existing engine, the more accurate our suggestions will be.
What trans do you have? If automatic, does the trans have a high stall converter? What rear axle ratio? Has the suspension and drivetrain been upgraded to put the power to the pavement?
Simple, free mod... 6HP.... take the two coolant lines off the bottom plate of the throttle body, and connect them together with a 3/8" hose barb. Don't drip coolant on the Optispark distributor.
Old Nov 6, 2014 | 02:59 PM
Re: bolt ons
It's a 6 speed. I can't find carb legal headers so exhaust is stock for now. The cam still passes smog so I can't put a different cam. I have the bbk 53mm throttle body. Injectors are also stock. I also put a msd optispark
Old Nov 8, 2014 | 12:53 AM
Fatdog2's Avatar
Re: bolt ons
Injuneer help me out here please.If an engine is built 383,would stock injectors be part of the formula.Doesn't make sense to me,but what do I know.No slam here,just wanna know.My02
Old Nov 8, 2014 | 08:03 AM
Re: bolt ons
If the engine was making 360HP or less at the flywheel, stock injectors would work. Or, if someone has increased the fuel pressure, they would work OK at even higher HP.
Old Nov 9, 2014 | 01:08 AM
Re: bolt ons
What was that about the throttle body? How do you do that bypass thing?
Old Nov 9, 2014 | 01:11 PM
Re: bolt ons
Exactly as stated in my earlier post. But if someone added an aftermarket throttle body, I would think they would have bypassed the coolant.
PS: There are 52mm, 54mm and 58mm aftermarket throttle bodies.... no 53mm.
Old Nov 11, 2014 | 11:37 AM
Re: bolt ons
My mistake its a 53mm. A friend of mine installed it for me so I'm not sure if he did. Does the bypass effect anything?
Bxlt1
18
May 27, 2015 05:00 PM
cristian1311
May 14, 2015 07:34 AM
cristian1311
Apr 23, 2015 08:36 AM
cristian1311
Apr 22, 2015 10:20 PM
79RS
Mar 24, 2015 09:30 PM
