Blinkers keep going out.... constant problem
Old Jun 19, 2006 | 03:47 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
moisture keeps killing my front blinker bulbs even though i COVER them and FILL the sockets with dielectric compound... i know this is caused by some kind of broken housing or whatever easily letting water in to drown them, people keep telling me... but i can't see anything abnormal about anything around the blinker system at all... what is the piece/pieces i need to replace exactly?
thanks for any help,
Jared
Old Jun 19, 2006 | 11:31 PM
stingant0's Avatar
Re: Blinkers keep going out.... constant problem
Try taking your lenses out and filling them up with water. If any water leaks out, then you know where to fix it. Then get some clear super glue and fill in the cracks. Let it dry and then fill it back up with water and see if you fixed it.
This worked for me and the super glue was clear, so it isn't noticeable. I hope this helps.
timmy39120
May 8, 2015 11:41 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
mattstrike
Mar 24, 2015 02:11 PM
