Blinker stopped blinking
Old Aug 1, 2004 | 03:12 PM
97droptopZ's Avatar
Exclamation Blinker stopped blinking
When I put on my left turn signal, it just stays solid the whole time. It doesnt blink in the dash cluster or in the front or on the taillights. It just stays solid. Anyone have any experience with this?
Old Aug 1, 2004 | 03:15 PM
n2ceptor's Avatar
Re: Blinker stopped blinking
Check the flasher...
Old Aug 1, 2004 | 03:34 PM
Most often, it is a bulb element that is burned out. Look at the bulbs, front and rear. Compare to the other side, if needed.
Old Aug 1, 2004 | 05:35 PM
Dave88LX's Avatar
Make sure you top off the blinker fluid too.
Old Aug 1, 2004 | 06:28 PM
atljar's Avatar
Ditto what he said. Turn on the left flasher and get out of the car. Either the front or rear will be solidly lit, the other likely wont be lit at all. Replace the one not lit, and everythign should flash again
Old Aug 1, 2004 | 06:33 PM
96WhiteZ28's Avatar
I had a loose bulb in my rear left taillight and only my right turn signal blinked and my left turn signal was steady. I had to change the whole socket from a junkyard taillight harness i bought. I'm not sure if the same would apply to a burnt bulb.
Old Aug 2, 2004 | 01:57 AM
JDBlaze85's Avatar
check the blinker fluid
Old Aug 3, 2004 | 02:28 PM
97droptopZ's Avatar
I checked both bulbs in the front turn signal assembly and they both work. I also noticed that it lights up more than the other signal when the blinker is on. The taillight turn signal also works, it lights up solidly. Could there be another thing that could cause this? Its like it is stuck lit up and doesnt blink.
Old Aug 3, 2004 | 03:40 PM
If one side looks brighter or dimmer than the other, you might have a grounding or a socket problem. You should also try changing the flasher if you have not already. It's easier than chasing socket problems.
Old Aug 4, 2004 | 02:59 AM
Nittanymarine's Avatar
most likely, in my experiences, it has been a flasher. good luck to you.
Old Aug 4, 2004 | 11:34 AM
97droptopZ's Avatar
Would it be a bad connection at the flasher, or just a bad flasher all together?
Old Aug 4, 2004 | 01:32 PM
n2ceptor's Avatar
Just the flasher, from what I have seen... If it is not it, then it might be the turn signal switch itself, but make sure all connections are good at the bulbs and you have good grounds...
Old Aug 6, 2004 | 11:31 AM
GRndPNdN93Z's Avatar
i had the same thing happne to me in my 93Z and all i had to do was change the bulb, mine had one of the elements had burned out and touched the other element that was still workin so in essence i had like a short, changed the bulb and viola it was fixed
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
4586
Sep 27, 2015 01:55 PM
KYWes
Sep 26, 2015 08:49 AM
mark0006
Sep 14, 2015 12:35 PM
Aaront810
Sep 11, 2015 11:24 AM
