Bleeing power steering...
Old Jun 11, 2004 | 09:38 PM
96z's Avatar
96z
I found my power steering leak and fixed it. I started the car and the pump was whining like crazy. I turned the car off, added more fluid to the resivour and turned the wheel back and forth about 10 times and repeted this twice? Is this how you bleed the power steering? Now the resivour is full of bubbles but the pump still whines?
Old Jun 11, 2004 | 10:13 PM
n2ceptor's Avatar
I believe Shoebox's homepage has the info you need..
Old Jun 12, 2004 | 12:35 AM
#7's Avatar
I usually fill res. wait 3-5 min. check level fill if need.Jack front of car up get wheels off ground. turn lock to lock 25 to 30 times checking level every 5 being I have a large aftermarket cooler.But 20 is good for non cooled. MOTOR OFF while doing this. Then recheck PS fluid level lower vehicle start/run car and turn lock to lock about 5-8 more time to be sure its good.
With yours after what you have done I would now let it sit for quite awhile let the bubbles disapate as much as possible and do the above.
Tony
Old Jun 12, 2004 | 02:38 PM
96z's Avatar
96z
Thanks, Ill do that right now, I was in a rush to get it on the road and didnt think.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Keenan
Jan 19, 2023 12:24 PM
DarkKnight
Exhaust System
19
Oct 17, 2016 10:28 AM
NewsBot
May 16, 2015 03:40 PM
XtremeLt1
Sep 13, 2002 08:50 PM
