belt tensioner problem?
Old Aug 1, 2006 | 07:09 AM
contraststriker's Avatar
Sometimes my belt squeels, and I have no idea why. It only does it under load, not idling. Really though this is a fairly intermittent problem, amplified when the belt gets at all wet (my hood has one small leak). Also it consistently skips one rib towards the rear of the car if I go above 3k rpm. Are these problems correlated? Maybe when I shift at a higher rpm the change from lots of torque to none is too much for my old tensioner and it skips a rib? What about the squeeling? Thanks~
Old Aug 1, 2006 | 02:39 PM
n2ceptor's Avatar
Re: belt tensioner problem?
What belt brand are you using????? Seems like the tensioner is worn....
Plus check the idler pulley...
Old Aug 1, 2006 | 05:38 PM
OBE1 95Z28's Avatar
Sounds like the tensioner is weak if the belt is shifting around. The belt has probably been abused by this so I recommend you replace the belt too.
SpeedJunkee
Apr 23, 2015 09:51 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
Snoman73
Nov 17, 2014 07:22 PM
1LEThumper
Jul 14, 2003 12:45 PM
