BBC Wiring in a 4th gen?
Old Jan 16, 2008 | 05:46 PM
Joes96z's Avatar
Has anyone on here put a big block in a 4th gen? i am starting this project very soon, and I was wondering what you used for the wiring of the car?
Any info would be great, even if it doesn't pertain to my question
Thanks, joe
Old Jan 16, 2008 | 06:39 PM
The first item on your list should be a search. The BBC in a 4th gen is asked frequently.
Old Jan 16, 2008 | 06:51 PM
BMoney's Avatar
if you are going with a older BBC, then the only thing you need is your starter wire, alternator wire, and a power wire for your ignition(HEI, or MSD).
Old Jan 16, 2008 | 07:25 PM
Joes96z's Avatar
What about headlights, taillights, gauges, etc. Do I keep the LT1 PCM for some of that. Or can I use some set-up from a place like painless?
Old Jan 16, 2008 | 09:19 PM
ulakovic22's Avatar
What kind of BBC do you have? If it's a standard carb'd motor then you don't need much. All chassis wiring has nothing to do with engine and will work as it did before. Gauges you will need to run your own wires for like oil pressure, RPM, etc. Won't need the LT1 PCM for anything other than fans and maybe a few other things. If you search you should find the info.
Old Jan 16, 2008 | 09:23 PM
Joes96z's Avatar
I am doing a carb'd bbc.
Old Jan 17, 2008 | 06:49 AM
http://www.att.net/p/s/community.dll...geid=28387&ck=
sahlomonic
Parts Wanted
Sep 19, 2015 10:17 AM
Roadie
Feb 16, 2015 10:34 AM
4586
Dec 31, 2014 02:21 PM
Jul 4, 2005 05:00 PM
