battery ground
Old Aug 31, 2004 | 02:23 PM
ram air camaro's Avatar
battery ground
hey shoebox i got one for you, i was looking at your site and came across one of your exploded views where the ground from the battery conects to the motor mount for ground right, now my car has that ground on the bolt from the struts under the hood you know where the 3 bolts to remove thee struts well right there.
is that a good place for a ground to be ?? i'm thinking that could be it
Old Aug 31, 2004 | 03:12 PM
Re: battery ground
There are two grounds from the battery. One goes to the block (at the motor mount) and the other goes to a lug on the RH shock tower, that is just behind the positive junction (the one with the red plastic cover). Is that what you mean?
If you don't have a heavy ground cable from the battery to the engine block, you should.
Old Aug 31, 2004 | 03:46 PM
Re: battery ground
ok i got one running to the lug by the positive wires wich should be there and the other ground (heavy duty) is on the lug of the strut shock i'll conect it to the motor mount where it should be
do you think that could be causing my slow starting problem ?
Old Aug 31, 2004 | 04:16 PM
Re: battery ground
It very well could. Are you getting slow cranking? I bet if you checked the braided ground strap to the coil (you have one of those, don't you?) after trying to start the car, it would be hot . The big neg cable needs to go to the engine. Right now, you basically have two chassis grounds and no engine ground.
Old Aug 31, 2004 | 07:37 PM
97z28/m6's Avatar
Re: battery ground
if the ground is broken(wire) will it cause it to die right after it starts?
Old Aug 31, 2004 | 10:19 PM
95WhiteTA's Avatar
Re: battery ground
shoebox, i have some trouble with charging sometimes, when i have my ac and fans on. could i have a bad ground, cause i know my alternator and battery are good. what else could it be?
walt355
Mar 16, 2016 09:35 AM
92_RS_305
Sep 8, 2015 07:47 PM
4586
Aug 22, 2015 01:09 AM
4586
Aug 18, 2015 07:08 AM
