Bank one 02 sensor?
Old 08-03-2005, 12:24 PM
95TA8280's Avatar
Bank one 02 sensor?
My SES came on and it said I had a problem with my bank 1 O2 sensor. I called Jason for the part, and he needed ot know if it was in the exhaust manifold or the cat. Which is it in?
95TA8280 is offline
Old 08-03-2005, 12:59 PM
Kataklysm's Avatar
Re: Bank one 02 sensor?
If its bank 1 sensor 1 it is in the manifold, bank 1 sensor 2 is the cat.
Kataklysm is offline
Old 08-03-2005, 01:33 PM
Since you have a 1995, you should only have one sensor per side and it is before the cat. It should be GM PART # 25312184 .
[edit] I just glanced at your sig. I realize now that you may not have a 1995.
shoebox is offline
Old 08-03-2005, 02:11 PM
You might want to give us the specific code.... there are multiple codes for each O2 sensor, and not all of the codes mean the solution is replacement. Sometimes the O2 sensor code shows up as a result of other problems.
Injuneer is offline
Old 08-09-2005, 02:36 PM
95TA8280's Avatar
It's for my 01, not 95...
I think I tossed the code and Autozone cleared it fromthe computer. Does this mean I need to go around spending $15 on a gas a day until the SES comes back on?
95TA8280 is offline
Old 08-09-2005, 03:45 PM
I don't know how else you are going to know the code until it appears again. I'd worry about it when it comes back.
Also, your code description was incomplete. It should have said "bank 1, sensor 1" or "bank 1, sensor 2". That's probalby why Jason did not know which one you needed.
shoebox is offline
14
08-11-2015 12:03 PM
whitehooptie
08-10-2015 07:02 AM
08-07-2015 01:26 PM
zajones
07-30-2015 02:18 PM
Noct
07-14-2015 01:18 AM
Quick Reply: Bank one 02 sensor?
