Bad Vibration under moderate and heavy braking...
2001 Camaro Z28...
Braking at any speeds greater than 50 MPH or at ANY speed with more than 1/4th brake pedal, I get vibrations... The entire car shakes its way to a stop and the pedal feels like it's pulsing slightly... I really can't pin point exactly where the vibrations are coming from... my wildest guess would be to say the front but Im really unsure as it's the entire car that vibrates and no specific area... Is this normal or what should I look into? I'm at 57K Miles...
Edit: I'm also aware I spelled heavy wrong in Title...
Today i just bought new rotors and pads for my truck which was shaking very crazily, so annoying everytime i go to stop it shook soo bad, but it stops so nicely now, i would agree with everyone else it is the rotors and pads.
Re: Bad Vibration under moderate and heavy braking...
Before you spend the money to have discs turned, you might check the cost on new ones. Many times, turning will put the rotors out of spec. for thickness or the thinner rotors will be even more likely to warp.
My rotors were like 26 buck a peice( not the best ones) they seem really good though because i got the best pads. The better rotors were like 39 each or somethin. my truck is very heavy and it was very annoying stoping and shaking like it did, i mean the steering column shifter would go crazy along with the steering wheel. It stops so smooth now it feels so weird now. lol. Yea it deffinitly is worth it for new rotors.
96SilverRam
Nov 20, 2016 11:19 AM
Apr 16, 2015 09:57 AM
Apr 3, 2015 10:54 AM
. Had mine turned once already and it cured it for the most part
