Bad Gas in tank
Bad Gas in tank
Well, on the news they have been reporting that some gas stations have some sulfur in there gas. http://www.kristv.com/ That is the news link and on the side that says featured videos, the last video is about the tainted gas. Everything they said that happens with it showing it is full and it is not. I filled up at a Citgo on Thursday and it shows still full, even though the city I filled up is about 22 miles from Corpus, but still part of Corpus. I have put at least another 30-40 miles and it has not moved a mark. My question is, what do I do? Can get all the gas out, run some gas treatment, or do I have to replace the sensor in the tank?? Any help is appreciated. Thanks!
Re: Bad Gas in tank
well i know all the z's ihave had, stays at the full mark for a while, even after 30-40 miles it'll still stay full, and then once it hits like 75 of so it starts coming down,
Re: Bad Gas in tank
It says on the full mark, but I did not full it up all the way. I just found out now I cannot even put more gas since it reads full
Into the garage till tommorrow so I can drop it off at the stealership
Re: Bad Gas in tank
time to drop the rear and pull the tank on that beast... have fun, definately go for a class-action lawsuit w/ others around your area... hell, it might even pay for some more go-fast moddies on it
~Jon
~Jon
Re: Bad Gas in tank
~Jon
~Jon
Re: Bad Gas in tank
Last I knew the sulpher issue was only from one shell plant here in LA.. Our shop has done around 30 Pumps/sending units from this. If your gauge complatly stops moving then you have a problem.
Re: Bad Gas in tank
Yeah the needle does move when I turn it off. When it is on, it jumps straight to full. The pumps I went to are closed down. So I am thinking they found out. Time to get my 250 back for the repairs.
Re: Bad Gas in tank
Here you go.
http://www.interactclaims.com/shell/
This is an old issue, so I don't know if it will do you any good. But this is the place to submit the claim. They have paid all around here that had proof that they bought gas at Shell, Texaco, or Chevron stations. They are all under one big corporate umbrella.
Good luck,
PJ
Good luck,
PJ
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
Deadbolt24
Jan 19, 2015 01:29 PM
