Bad BCM??????
Old Nov 13, 2004 | 03:42 PM
Red97LT1's Avatar
Question Bad BCM??????
My interior lights will some times pop on when i open the passenger side door and some times it won't. It will sometimes chime when i try to lock the door and the passenger side door is open. The drivers side works fine. i have replaced the door switch and the switch is getting power.Could the bcm be bad???
Old Nov 13, 2004 | 04:20 PM
Red97LT1's Avatar
Re: Bad BCM??????
Well,i wnet back out to try some other things and now everything is working fine. I didn't do anything,so i don't know what happen.I'm leaving along unless it does it again.
Old Nov 13, 2004 | 04:47 PM
Kataklysm's Avatar
Re: Bad BCM??????
Weird things like that happen alot. My keyless entry randomly stops working for a few hours then it's fine. If it with lights you should check wiring, could be a bad connection.
Old Nov 13, 2004 | 09:17 PM
Re: Bad BCM??????
The door jamb switches working by completing the connection of the circuit to ground. Perhaps you have an intermittent or weak ground on that door jamb.
Old Nov 13, 2004 | 10:42 PM
Re: Bad BCM??????
Perhaps it might help if you looked for troubles codes from the BCM.
OutlawPerforman
Oct 30, 2017 05:40 PM
Jocofire1
Aug 7, 2015 03:16 PM
zajones
Jul 30, 2015 02:18 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
