anyone done a ls2 swap...please chime in. i'm doing it soon
hey all, it's been a while i know...but that's only cuz my camaro's in jersey and i'm in TX...so i havent really had a need for the site. but i'm working on getting it finished soon and hopefully havent pissed anyone off by not being here.
any way, to the goods...or needs.
basics:
97 camaro, lt1 with manual t-56.
needs:
ls2 gto transplant info.
i need to know everything i'll need. here's what i KNOW. ls1 k-member from 98+ trans/Z. i'll getting a pullout that's including turnkey engine, trans, harness, and pcm...so i have those. i'm running my ltx k&n, suspension other than k frame, and i'm using my ltx alum. driveshaft.
do what fuel setup will i need? 97 vette? custom rails?
what trans tailshaft adapters will i need? is the GTO the same as camaro or can i use my camaro's tailshaft adapter?
will the accessories from the GTO fit directly or do i need the camaro's ls1 accessory brackets?
can i use the lt1 trans mount/cross brace?
is the lt1 radiator sufficient for the ls2?
will i need a different fuel pump?
stuff like that? i know it will fit, and i know i need the lsx k-member to make it fit. but what else?
oh, and i did search both the ltx and the lsx forums. thanks for your input
basics:
needs:
ok, for those who want to know, here's what i found.
camaro oil pan
knock sensor extension or conversion
maf extension or conversion
if converting from ls1 then you'll need a ls1 crank reluctor ring (yes, rebuilding the engine)
injector harness adapter or a ls1 fuel rail and injectors.
i'll be using teh oem wire harness from the gto, so i wont need most of this. and i havent figured out if i'll need the tailshaft from my 6-spd trans yet
camaro oil pan
I'm in the process of getting an ls2 drivetrain from a 07 trailblazer ss in my camaro wish I could tell you all thats involved but I payed a shop to do mine.
Formula Steve
Sep 19, 2023 08:31 AM
WobblySausage
Oct 7, 2015 02:44 PM
CARiD
Sep 30, 2015 05:44 AM
