Another 'removing heat fuse fixed my window motor'
Old May 17, 2005 | 10:33 PM
  #16
Terran2k's Avatar
Re: Another 'removing heat fuse fixed my window motor'
hey eej, how's that motor holding out for you, the one you fixed??
Old May 18, 2005 | 08:22 AM
  #17
wogert's Avatar
Originally Posted by qwerty95z
how much time would you say this takes in all?
I just replaced the motor for the first time ever. Opened my Haynes manual... useless!
I got the regulator, motor, and glass out of the door in about 1-1/2 hours. Then spent WAY too much time driving back and forth to the hardware store.
Reassembled the next morning in about 1-1/2 hours, before work.
BTW, if you want to save some time, buy the hardware ahead of time... if you are going to bolt everything back together instead of rivet...
7mm fit best in the regulator holes. I think I used 16mm long and I used lock nuts.
4mm fit best in the motor holes. These were 12mm long and also used lock nuts.
Old May 18, 2005 | 08:37 PM
  #18
eej's Avatar
eej
terran2k:
Still works..same motor. Wow just noticed the date on my original fix. July 13 2003. Almost 2 years and still works.
jayvar
Feb 2, 2015 10:00 PM
Fatdog2
Jan 24, 2015 12:08 AM
Jazsun
Dec 29, 2014 12:14 PM
MislMan
Jul 19, 2002 11:41 AM
