am I killing my alternator?
Old Mar 16, 2008 | 07:03 PM
Krypnosis's Avatar
I had my original alternator fail on me recently and since then replaced it with a new/reman unit. I installed the new alternator and my car has been running fine since last thursday, but now today after I floored it through these S turns on the way over to a friends house...I happened to glance at my battery gauge and it was right about where the red area starts and my check gauges light came on . My car has been running right around 13.5 before I floored it.
Old Mar 16, 2008 | 08:03 PM
2000GTP's Avatar
Some "spirited" driving shouldn't hurt your alternator. Keep in mind that the voltmeter gauge on the dash isn't always 100% accurate. If you have access to a multimeter, you could measure the actual battery voltage across the terminals and compare.
Old Mar 16, 2008 | 10:56 PM
GreasyB's Avatar
Take his advice and report back.
Old Mar 17, 2008 | 02:35 AM
Fuel Fire Desire's Avatar
Ive had "new" alts from autozone fail on me after a few months before. Even had to go through 3 reman alts to find one that actually put out what it was supposed to.
Wouldnt surprise me if it really did fail.
Old Mar 17, 2008 | 01:33 PM
Krypnosis's Avatar
I measured 12.64 volts across the terminals with the car off and 11.85 with the car turned on and the voltage did not increase after that. I am going to remove the alternator and have autozone test it to see if it's any good...even though they tested it before I installed it and verified with me that it was good.
Old Mar 17, 2008 | 01:35 PM
2000GTP's Avatar
While you are taking the alternator to be bench tested, you ought to take the battery with as well and have them load test it. Also, make sure that all of your connections are clean and tight when you reassemble.
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
Pwilson59
Sep 3, 2015 08:47 PM
