Alternator
Alternator
WOW... Im running new wires for my new alternator.. standard AC delco on a sbc... and for some reason the dam thing wont stay runnig when I pull a battery cable for the good ol easy "alternator test"... Im rewiring due to old wires and a new MSD 6AL box... I feel like an idiot its 3 dam wires:dunno:
ooo its a 67 camaro if that matters much
Re: Alternator
Don't do that "alternator test", can fubar stuff. You need to put a multimeter on the output stud and measure voltage there. It should be a fraction of a volt higher than your battery reading with the engine running. ~ 13.5 - 14 is normal at the stud.
Were you aware of the possibility of engine run on when you install an MSD box?
http://www.msdignition.com/1troub1.htm#runon
Re: Alternator
This is for a 70 Buick, but the wiring is basically the same for all external regulator GMs:
http://www.rowand.net/Shop/Tech/imag...-1970Buick.jpg
tommalcolm
Sep 11, 2015 03:39 PM
