Airbag code
Old Apr 25, 2005 | 06:05 PM
Savage Messiah's Avatar
Airbag code
I was in an accident, and it caused my airbags to deploy. I was wondering a few things about this, since the damage isn't too bad and I'm fixing it up.
1) Where is the front airbag sensor? I can't find it (97 V6 Camaro).
2) I have new airbags to put in, but before I do it I was wondering about the airbag code. I'm assuming that if I just install my new ones they'll pop right out since the code is still there. If I remove the airbag fuse and disconnect the battery, will that reset it, or do I need to clear the code out of the computer?
3) Can I reset the airbag sensor, or is it a one time use type of thing?
Thanks in advance.
Old Apr 26, 2005 | 03:00 PM
Re: Airbag code
Got this answer off of camarov6, just wanted to make 100% sure
Originally Posted by 98Camaro3.8
The Inflatable Restraint Sensing and Diagnostic Module is in the center column, next to the shifter. It uses an accelerometer to measure the force of an impact.
The service manual says that any time the airbag is deployed, you must change the SDM.
Fastbird93
Apr 9, 2016 07:01 PM
beltrunner
12
Jul 15, 2015 08:39 PM
Lakebratt
Feb 5, 2015 07:55 PM
formula218
Dec 2, 2014 04:27 PM
91Bird305
Aug 5, 2002 01:39 PM
