Air Compressor removal
Old Aug 3, 2011 | 01:44 PM
jcl69cam's Avatar
Never changed a air conditioning compressor before, what is the best method in the removal. From the top or under the car? I'll be having the evac/refill after the install of the compressor/Dryer and new o-rings. Thanks in advance.
Old Aug 4, 2011 | 12:47 AM
L.dookie's Avatar
Re: Air Compressor removal
from the bottom.
Old Aug 11, 2011 | 08:25 PM
Nickw059's Avatar
Def the bottom. put the car on jack stand. evacuate the system, If i remember right, the bolt on the lines to the compressor was a pita, but otherwise than that it was pretty simple. I removef the belt, tensioner, 1 cooling fan (Made it a little bit more easy!) 3 bolts for the a/c compressor. I did mine a while ago so I might be leaving a little info out. lube the o-rings with pag oil.
Old Aug 12, 2011 | 06:57 PM
jcl69cam's Avatar
Ok, Thanks.
DirtyDaveW
Dec 1, 2016 05:37 PM
alphaauto
Jan 23, 2015 07:42 AM
95chwagon
Jan 13, 2015 09:19 PM
97SSdude
Dec 31, 2014 07:43 PM
