air bag removal procedure
Old Jan 12, 2007 | 06:05 PM
19camaro71's Avatar
I have searched and searched... and i know how to get the driver's out, but what is the process for the passenger side? Does anyone have a link or something to a step by step procedure to completely remove the airbag system? (im looking for something similar to those.. "how to change a camshaft" instructional things)
Thanks in advance!
Old Jan 14, 2007 | 05:07 PM
revtime's Avatar
I am sure there is a write-up floating around somewhere but you are going to have to remove the entire dash to do it right.
Get the wiring and everything.
Old Jan 15, 2007 | 02:25 AM
Z95m6's Avatar
Ditto you'll have to remove the entire dash and then it's held in by like 8 screws.
Old Jan 17, 2007 | 12:07 PM
Bayer-Z28's Avatar
From what I've heard from my uncle... DON'T QUOTE ME ON THIS!!.... The order I THINK is; Batt dissconnect, front impact sensor, then mid impact sensor then the airbag.
There is a certain order the switches have to be disconnected w/ out setting the bag off.
Old Jan 17, 2007 | 01:35 PM
Z95m6's Avatar
Yeah thats wrong.
Old Jan 17, 2007 | 02:18 PM
Gun5's Avatar
ya very wrong dont mess with those before disconnecting the bags unless u want to set it off lol i think once the system loses contact with a sensor it goes off or atleast throws a code
Old Jan 18, 2007 | 06:48 PM
Malmhead's Avatar
disconnect neg terminal
unplug yellow connectors under each kick panel
remove airbags
straight from haynes manual
Old Jan 23, 2007 | 03:34 AM
lt11997's Avatar
Disconnect the negative battery cable, remove airbag fuse wait 10 minutes till you unplug any airbag stuff, and remove entire dash for passenger air bag. If you want to remove center console and cut the the wire form the airbag module to cluster so you don't have the airbag light on all the time.
Z28amustangklr
Middle Atlantic
Mar 28, 2015 03:08 PM
dale3in98
Feb 14, 2015 12:18 PM
Airplanedoc
Feb 1, 2015 07:14 PM
squarehead
Jan 15, 2015 07:02 PM
Jul 4, 2005 05:00 PM
