ac question?
Old Nov 9, 2007 | 10:33 AM
davidf4925's Avatar
ac question?
95z a4.. I put in a new air compressor and want to know if I can recharge it myself or if I have to take it to a shope to have anything else done to it. I don't need the ac right now, but i don't want anyone to turn in on and take a chance at burning up the compressor. I was also told that untill the ac system is recharged that I could not use my heater or defroster with out messing up the compressor, is this true. thanks for any help.
Old Nov 9, 2007 | 01:04 PM
popstoy's Avatar
keep compressor unlugged until you charge system.I would relace your o rings while your system is discharged there a couple of dollers
Old Nov 9, 2007 | 01:13 PM
davidf4925's Avatar
I did replace the rings, just want to know if I can charge it my self or if a shop has to do it. thanks for the reply.
Old Nov 9, 2007 | 01:28 PM
popstoy's Avatar
I just added to this thread i guess it didnt come up .yes you can they sell the kits with the hose together you would probobly need 2 cans .did you replace the reciever dryer and oil up the compresser.
Old Nov 9, 2007 | 02:04 PM
JohnD's Avatar
Unless you have a pump to pump the system down and gauges to check it, you can't do it yourself. It's a good idea to pull vacuum on the system and leave it a while to be sure that it is tight too.
Old Nov 9, 2007 | 02:51 PM
2001NBMZ28's Avatar
If there's no refrigerant in the system the compressor shouldn't come on, pressure switch should keep it off. Since you've already done the hard work, and it's been open to the atmosphere, I'd bring it to a shop so they can pull a vacuum on it, then charge it.
Old Nov 9, 2007 | 02:58 PM
davidf4925's Avatar
thanks, that is what I was going to do...
Old Nov 9, 2007 | 03:20 PM
Gord's Green Z28's Avatar
Pulling a vacuum on the system is ESSENTIAL to good performance.
Heater doesn't use the compressor. Go ahead and use that. As has been mentioned, you can run the defrost, it just won't run the compressor along with it since the low pressure switch will keep it from cycling on.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
