AC problems
Now that it is starting to get hot out around here its time to address my AC not working. I had it checked out last year and they recharged it but it only worked for a week. Unfortunately I got that for free and couldnt follow-up to see what was wrong. Anyways it works and blows cold for about 5 min and then it seems to pick up all the humidity in the air and pulls it into the car.
Any ideas? I have a 95 v6 camaro. Thanks.
Re: AC problems
Your best bet is to inject some dye into the system and look for leaks. Clean all around the fittings first, then put the dye in. You'll have to run the a/c for a few days and then look for the leak with a special light and glasses.
The hardest part to find the leak is the condenser ( in front of the rad) and the evaporator which is in where the heater core is.
Magenta_Hearts
Mar 25, 2015 10:24 AM
