AC Delete Pulley ?
Old Feb 18, 2005 | 06:44 PM
DarkRider's Avatar
AC Delete Pulley ?
At GM Parts Direct I just put in PN 10115875 for the ac delete pulley.
It says for 93-95 camaro. I have a 97 camaro Z28, is it still the same part or is it a differect pulley.
Just want to make sure before I order the wrong part
thanks
Josh
Old Feb 18, 2005 | 10:17 PM
Kataklysm's Avatar
Re: AC Delete Pulley ?
I would imagine they are the same unless they made one of the other pullies smaller. Nothing changed on the front of the engine to my knowledge.
Old Feb 18, 2005 | 10:44 PM
You might try a search, but I am pretty sure that this was answered before saying that it will work on 93-97s.
Old Feb 18, 2005 | 10:47 PM
96camaroz28lt4's Avatar
It's all the same, maybe it just told you wrong. I've seen around some places where it says 92-97. All you have to do is unbolt the ac compressor and the tensioner and pull the thing out (removing tubing from the back etc. of course.) Easy job.
Old Feb 18, 2005 | 11:12 PM
drivefast4fun's Avatar
be a little careful if you have underdrive pulleys, after I put on the AC delete pulley on my 97, I could not find a belt the right size to fit with my underdrive pulleys on, so I had to put the stock ones back on!
Old Feb 19, 2005 | 11:22 PM
94Z & 96SS's Avatar
I had under drive pulley too. Come to think of it I used the same belt that I had with the A/C.
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
tnmotown
Aug 10, 2015 11:52 PM
