AC Delete Pulley ?
AC Delete Pulley ?
At GM Parts Direct I just put in PN 10115875 for the ac delete pulley.
It says for 93-95 camaro. I have a 97 camaro Z28, is it still the same part or is it a differect pulley.
Just want to make sure before I order the wrong part
thanks
Josh
thanks
Josh
Re: AC Delete Pulley ?
It's all the same, maybe it just told you wrong. I've seen around some places where it says 92-97. All you have to do is unbolt the ac compressor and the tensioner and pull the thing out (removing tubing from the back etc. of course.) Easy job.
be a little careful if you have underdrive pulleys, after I put on the AC delete pulley on my 97, I could not find a belt the right size to fit with my underdrive pulleys on, so I had to put the stock ones back on!
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
