AC compressor wiring help
Old Jul 14, 2006 | 02:18 PM
abecker_xr250's Avatar
So my AC doesn't work, and that sucks because it's really hot right now. This past spring I fixed a bunch of wiring in my engine compartment, including the wires going to the AC compressor clutch. I think I might have reversed the wires in the plug, I had it all apart so I could slide heat shrink onto the wires. I was wondering if someone could tell me which color wire is supposed to be where, driver/pass side or something so I could look and see if thats what I did. Also, where is the fuse for the AC clutch, it shows one in my service manual but its not in the fuse block with the rest of them. Thanks for your help.
Sincerely,
Roasting in Minnesota
Old Jul 14, 2006 | 02:36 PM
2001NBMZ28's Avatar
Re: AC compressor wiring help
Info on your car? Make a short signature even if it's stock.
Old Jul 14, 2006 | 05:51 PM
Sorry, I thought I had a sig set up here, I post more on a different forum. It's a '95 Trans Am, M6, not too many mods. I'll get a sig set up tonight or when I get a chance, thanks.
Old Jul 14, 2006 | 06:44 PM
The dark green wire goes to terminal A of the plug and the black wire to B. The factory harness has a diode spliced between these wires, approximately 2.5 centimeters from the harness breakout by injector #2. It is there to prevent electrical spikes when the compressor is turned off.
willismoons
May 27, 2015 04:03 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
alphaauto
Feb 5, 2015 05:25 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
