AC Compressor Problem
Old Oct 30, 2004 | 03:12 PM
Z28COnrad's Avatar
The AC compressor in my 98 T/A is not engaging when I turn the AC on. I have replaced the relay in the fuse box with no results. Any help is appreciated. Thx.
-Conrad
Old Oct 30, 2004 | 03:37 PM
Josh'95Z28conv's Avatar
Re: AC Compressor Problem
Is there enough refrigerant in the system?
Old Nov 2, 2004 | 07:01 PM
PeteZ28's Avatar
Yeah, he's right, your system probably needs refrigerant. There's a pressure switch that stays open if the system isn't charged properly.
Pete
Old Nov 3, 2004 | 08:20 PM
GoFast908Z's Avatar
Member
not to jack your thread, but my a/c is barely working. While driving, it is noticably cooler than at idle. When I come to a stop its like the A/C turn off leaving the fan on. It takes 45 min of driving to cool my car down. About a year ago, I had the system recharged, so it should not need that again. Whats the problem?
Old Nov 3, 2004 | 08:36 PM
Fuels94TA's Avatar
ditto, must have low feron.
Old Nov 4, 2004 | 03:33 AM
PeteZ28's Avatar
Yeah, probably low freon too. You could have a leak. Or it could be the orifice tube is clogging too, it reduces the pressure to the evaporator. Mine was clogged completely with metal chips.
Pete
Old Nov 4, 2004 | 09:56 AM
Z28COnrad's Avatar
alright I went to a friends house and we hooked up the little gauge and checked my refrigerant and it is compeletely empty! It was working fine one day then completely empty a week later, this means I have some sort of really bad leak...ugh...
99TransAmWS6
Feb 12, 2015 07:23 PM
alphaauto
Feb 5, 2015 05:25 PM
alphaauto
Jan 23, 2015 07:42 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
